View Single Post
Old 09-18-2006, 03:22 PM   #19 (permalink)
donmagicjuan
DSM Wiseman
donmagicjuan's Avatar
Region: Pacific Northwest
Classifieds Rating: (1)
Quote:
Originally Posted by denniegst
how long did it take you to reach those numbers? i was under the impression that it would take alot of time and effort to reach numbers like yours, with tunning and such forth. i know with fine tunning numbers like that can be reached; but when you are fine tunning arent you pretty much set on the car not being daily driver anymore? With a 50trim and an safc you can reach 300 hp, correct? Not much of a fine tunning but good enough for daily driving. I want a 300 hp daily driver car because i dont have that much time to fine tune, when im still in college trying to pass classes
I did the majority of my tuning on the street using 3rd gear pulls and the ECU+ simulated dyno feature. It's not the most accurate way to estimate horsepower, but it is an excellent tool to compare relative results after changing the maps. Once I was happy with my settings, I took it to a dyno to see what numbers it was really making. I paid for an hour session, and after some tweaking (mostly with timing) here and there, I arrived at the numbers I have advertised. I should note that the weather conditions were near 0 density altitude. The boost was actually around 26 psi that day with the water/meth injection, but whatever. I can only estimate airflow at about 38-40 lb/min, as Tom remembers, because ECU+ only reads out in MAS Hz. It was just a little formula I used based on other members' numbers from DSMlink. Hope that helps some.
Quote:
Originally Posted by GreddyGst
50trim can reach 300+hp with less effort and less time.
As much as I love my setup, I will have to agree with Luis on this. However, I still feel that a decent tune on a smaller turbo will be more fun than a haphazard tune making equal horsepower on a larger one. Just my .02.
____________________________
-Don
Offline
