Fett
- Sep 5, 2004
Duluth,
Minnesota
ok, a few questions for anyone who has done this swap, just wondering if this list is accurate for a 1g awd?
Clutch Peddle Assembly
Brake Peddle Assembly
Shifter Base Shifter and Shifter cables
Clutch Master
Clutch Reservoir and bracket that holds it to the firewall
Cluth line NO THE RRE one is not complete from fire wall to slave
Clutch Slave
You need a transmission
T-Case
Rear Diff
AND YES THEY HAVE TO HAVE THE RIGHT RATIO's! You will also need depending on what you have in the car right now, if you have LSD and swap to NON LSD you need BOTH rear CV shafts from an NON LSD car.
You also need both front drive shafts and the indermediate shaft
as it is from the tech article for the swap but for a 2g
i need anything else or dont need something on here?
thnx in advance
Clutch Master
Clutch Slave
T-Case
Rear Diff
thnx in advance
