View Single Post
Old 01-08-2005, 09:00 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #3 (permalink)
sweet97 Offline
Proven Member
Tech Posts: 2,388
Classifieds Rating: 5
Reputation: sweet97 is pretty helpful and trustworthysweet97 is pretty helpful and trustworthy
If you do not have an AFPR that is the problem and you will not be able to lean it out. The fuel pump is too much for the stock regulator. YES you bent the rod on the pump assembly. Check out the install on www.vfaq.com as they address the problem you have with no reading. Mark
