yes aluminum flywheels are 4mm thicker. you dont need new bolts ut im sure you wouldnt want it fallin off. i figured it was good security thatsd why i got mine
also gixx the locktite was a smart move. that stuff is great. as long as the bolts were a hair longer then the stock you should be ok. just need a little more surface with a longer bolt to grab with. the grooved washers were also a good step in keepin em in there. the stock bolts and the ones from forced performance i got have washers in em allready.
