Which/What gauges should I get? [Merged 12-6]
Look for a fuel gauge that has a sensor that plumbs into the fuel line, with wires that run into the car.
To answer your question, NEVER plumb a fuel line into the inside of your car...
Originally posted by 696
Can you run a fuel gauge inside your car "safely"?
696
-Yes, by using a sending unit, mount by the fuel source.
-EcLiPsEgSt97, don't waste $ on those blinking LED A/F gauge, get an O2 voltage gauge instead.
aight thanks....an O2 voltage gauge??? what does that do???the egt gauge should i buy the whole kit??? and where can i get it for a decent amount of money....plus by not having my cat-con....would that matter with any of the gauges....also just wondering which pillar looks better the 3 or the 2...i order the 3 gauge full pillar.its on its way....just want to know which one looks better????
-You can read about the O2 voltage gauge here
-If you want the blinking LED type A/F gauge, this person sell the more informative version.
-EGT gauge you need to gauge and the temp probe. it's better to get them as a kit with all the hardware.
Get the EGT w/ probe and wire in a kit.
Get an Oil pressure gauge (elec.)
If you get a Fuel pressure gauge get a mechanical and mount it under the hood this will save you from running back and forth while adjusting fuel pressure.
My $.02,
Joe
Like the title says. I've been searching the forums in this site and 2gnt, but can't find anything specific. I have a stock (except intake) 2g RS, and was wondering what gauges would be useful for me to have? EGT? A/F Ratio? Oil Pressure? Fuel Pressure? etc... Sorry if this has been covered before :|
EGT nope, no need unless you are running a added turbo setup or n2o
A/F nope, see above
Oil Pressure nope, not unless you are worried that you don't have any oil pressure or you just want to keep a eye on it.
Fuel pressue nope, not unless you changed your injectors or fuel pump for the means of adding a turbo in which you will need the a/f and egt gauges
The only gauge needed would be a volt gauge since DSM's all have charging problems. You can make sure you are charging at 14v.
Im thinking about getting a triple pod a pillar for my car. I was just wondering what are the top three like boost gauge, EGT, and like air/fuel or oil pressure? Something like that I was just wondering what people have. what they like and what is the cheapest to buy.
Originally posted by greathuskie
boost, EGT, oil pressure
Those are the right three. Pass on any blinkey lights. If your were to go with four I think I'd go for a Fuel Pressure before a water temp. The stock WT works as well as anything to alert you to a problem and that's all you need it for.
Steve
ok thanks guys but what like gauge company? and if they made them red lighted at night would be really nice too
Autometer is always good and accurate and some of them can light up red, such as the sport-comp series.
Darryl
Most series of Autometer gauges come with several light bulb "condoms" that alter the lights color, most common are red, green, and blue.
