Quote:
Originally Posted by ECLIPSEESPILCE
there is a kit that has a resivoier that is filled with a special liquid that is placed in the radiator fill hole. It allows you to draw air from the radiator to check for exhaust gasses.
It is called a block test.
http://www.arrowheadradiator.com/hea..._leak_test.htm
Here is crummy link but it shows the tool.
call around to a few shops and they might have one.
It only takes a few minutes to do.
Isn't this tool used to find out if you have a bad head gasket? If so, wouldn't I see if it was bad when I did a compression test?
