Best Injector upgrade for N/T
revsclipse
55
Oct 11, 2002
Roslindale, Massachusetts
Hey their fellow :dsm: , My name is Rev and I've done some upgrades to my 92 Eclipse gs, pacesetter complete exhaust system, K&N drop in, Urathane motor mounts, now I'm looking for better injectors and a fuel pump, any suggestions, please help.
Thanks Rev :dsm:
what lying bastard told you that you needed them?? cuz until you get alot more done than that you'll be more than fine with yours right now.
wont you just use more gas with bigger injectors? if so wait untill you ad more parts to your car. money on waisted gas is money you could be investing on parts.
Well if not Injectors, what should be my next upgrade:confused: Cams, pulleys, remove power steering. Let me know thanks Rev
I say get a fuel pressure regulator. Balance that air/fuel ratio out. That'll prolly bump you some HP.
underdrive pulley, cam shafts, cam gears, ported t.b. and intake, or header. take your pick with the mods you have all of these suggestions would be of more benefit than injectiors.
Well thanks for the great advice, I'm going to get started, I think the cam-shafts and the cam gears and underdrive pully is next. Does anyone know someone is boston too do the porting of the T.B this is where I need help Thanks again for all the great advice.
So are their any T.B's That are already ported for sale out their:confused: Also what is a good lifter upgrade, my engine is ticking.
1G T.B's anyone? Still looking for a T.B can anybody help? 92 GS
the stock 1g tb is pretty big, you could port it out, but it won't go much more than 4 mm or so. my buddy uses nt tb's as turbo ones and ports someout.
