View Single Post
Old 10-02-2002, 09:48 PM   #14 (permalink)
Otis
Proven Member
Classifieds Rating: (0)
Reputation: Otis is an unknown
you gotta tighten the living #@%#@%#@%#@% out of those belts. I think the size is a 390k4. tighten the hell out of it. you should barely be able to move it. I dealt with that #@%#@%#@%#@% for so long. just loosen the bolt on the side first and then tighten the tensioner. its 12mm bolts. once the tension is set tighten the side bolt again and you're done!
Offline
[posts] Reply With Quote
Sponsored Links
