View Single Post
Old 06-03-2004, 06:59 PM   #4 (permalink)
DSMNightmare
Proven Member
Region: Midwest
Classifieds Rating: (1)
Reputation: DSMNightmare is an unknown
He's right, if you can avoid it don't get an auto if you want to be quick. It's not that it can't be done... it just takes a lot and I do mean a lot of hard work and money. Beefing up the A/T can be done for cheaper than the build up of a M/T tranny. OR if you go the route I did it can end up costing you more. The Level10 tranny ends up running about 2500-3000 bucks but will hold a lot of hp. I had the higher stall in the car which made launching a breeze. On street tires I could pull 2.0 60fts all day long in my FWD A/T. I realize this is nothing big compared to an AWD but as far as FWDs go getting below 1.9 without traction adders is a bitch. I raced my FWD A/T for a little over a year or so and it was fun as hell to race. Best I did before I went to AWD M/T was 13.8@101mph@15psi on pump gas. Warren Daniel pulled 12.7 in his on pump with street tires.
So you can see it's not impossible, just more difficult. If you mod your A/T there are three things that are a must.
1. End clutch upgrade. Either Red Eagle or Alto
2. Shift Kit
3. Higher Stall converter.
Also note this.... If you have a 2G FWD A/T they DO NOT make a LSD for it. I shopped high and low and neither Quaiffe or Kaaz would do it. If you go 1G they do make it because Kiggly had one in his before he did the M/T conversion. BTW Kiggly did 10s in his A/T FWD 1G and Russ Coxe did 10s in his AWD 2G A/T.
Offline
[posts] Reply With Quote
Sponsored Links
