best MBC for your buck? [Merged 9-9]
CL MaNTis GST
775
Jul 16, 2002
A friend of mine is looking to get a MBC for his GST. I told him electric is the way to go, but he doesnt want to spend a couple of hundred dollars on one. I'm not too, too familiar with MBCs so which would you all recommend. Remember, he really doesnt want to spend too much money on one, but wants one that will do the job.
he asked about the $30 or so dollar ones from ebay, those any good?
thanks gang.
Originally posted by turbolaserAWDrs
dont listen to those ^^ people...they said that to me too when i asked...its not worth the hassle of making one than just spend a measley 50 bucks for the hallman one. BTW, just put mine in...it was EXTREMELEY easy, with the hose they supplied, i mounted it right behind the pasenger headlight. it only took two adjustments to get it where i wanted after the inital test that they told you how to do. IMO hallman is the best one for your money.
Hassle???? You can make them in like 10 minutes.
i like the dejon tool mbc....i think it it superior to the joe p or hallman or any homemade one...it has a machined body with thumbscrews to change and lock the position...and the instructions and hoses are good quality...my .02
Basically i need a MBC i am open for new suggestions but i want something good and i have brought it down to Perrin MBC, JoeP MBC XC, and the Hallman ES. If you have any info on any of these or any info on what u thinks is good please give me feedback. Thanx :talon:
Looks like you listed all the basic MBC's. Just go with the Joe P, it's the cheapest and most people use it.
Just like the title says, just looking for opinions on best (quality for price) Manual Boost Controller out there right now. (Price Range $50-$150)
i personally have a dejon right now...works good. u also might want to check out hallman or joe p. your price range will be plenty for a quality mbc.
Yeah, I'm aware of both Joe P. and Hallman boost controllers, but I'm looking for more specific models. What features should I be keeping in mind? I obviously want one that can easily be adjusted to a given setting without adjusting and testing.
Personally I like the HALLMAN EVOLUTION RX KIT but that's a little more than your wanting to spend.
I just bought a boost gauge pillar pod and a electric oil pressure gauge and now i want to turn up the boost its a 13g on a 5spd talon ? i dont know why he swapped to the 13 g but how much boost can i run on that setup
It depends on what you want. A simple easy MBC that works well and is cheap, lets see, a SBR MBC, TurboXS standard MBC (what I have, works perfectly), and theres a couple more, search for them. You sure its a 13g?? Also, are you still running the stock 450cc injectors?? Your fuel setup will determine how much boost you can run, completely stock, I'd run no more than 14 psi personally.
