Quote:
Originally Posted by nineD5_GS-T
Dont worry about being in the positive range. My car is in that range with 680's and a 2g MAS. Mine was at +22 on the low at 1000rpm. Just tune it to how your car likes it. Dont worry what the values are at on the low.
When you open it up WOT, your settings will find themselves going into the negative range by 7000rpm.
your MAF is probably hacked.
to the thread starter, 2G MAF and 680s, you'll probably end up in the -18 area.. i'd try starting out around -12 if i were you. assuming a stock 2G MAF. if it's hacked, start at all 0s
