1996 Mitsubishi Eclipse N/T Vehicle Profile & Build Thread
Street Build
My journey with the car from the day I got it through present.
dsmcrzy's Eclipse 20g 420a
Ownership Status
Currently Own
Turbo Type
20g
Drivetrain
FWD
Build Type
  1. Street
60mm MPx throttle body,
Borla ProXS muffler,
Audi R8 COP,
MPx under drive pulley,
prothane motor mounts,
Fuelab 545 FPR,
Fuelab 848 fuel filter,
GM Ethanol sensor,
afco radiator,
FIC high Z 900s,
Treadstone race manifold,
TD06 Frank 20g lvl 2 turbo,
Thermal Zero turbo blanket,
DEI Onyx starter blanket,
ssautochrome front mount intercooler,
NGR BOV,
Tial mvs wastegate,
Calan catch can v3,
Sitting on the shelf:
AMM intake manifold off bullettdsm’s car
Mods-Engine
40 over Wiseco 10.5:1 pistons,
Eagle rods,
Cleveite main and rod bearings,
remaned crank,
arp head studs,
PEP valves,
Crower valve springs,
OEM PT style lifers,
2.7l rockers,
Crane cams turbo grind 0014.
Melling high volume oil pump
Mods-EMS & Logging
Standalone Megasquirt MS3x,
Tiny I/OX,
Auto meter cobalt oil pressure, egt, fuel level gauges
14point7.com Spartan2 wideband.
Digital gauge cluster using a Raspberry pi4 running tunerstudio ultra and arduino uno For the turn signal and high beam indicators.
Mods-Drivetrain
south bend clutch stage 3 (non-modular conversion),
New MC, SC and SS line
B&M short throw shifter,
Skate board bearing ends,
Tein basic coilovers
Prothane everything
Drag DR-31 17x8 +35mm off set
Toyo proxy 4s 225-45
3g master cylinder and 8+9 Booster
Greengoblin's fender braces
JDM Galant front knuckles
Evo Brembos front and rear
JNZ SS DSM/evo brake lines
Bobby’s adjustable upper rear arms
Parts Wishlist
Borg Warner EFR turbo...
Background
Traded a pack of cigarettes for the car when I was 19 (2007). The goal is to get the car turboed with a HP goal of 300. After that I would like to autocross it. The someday plan is a full evo awd swap with gobs of HP.
2G DSM
dsmcrzy
Watchers
13
Comments
4
Rating
5.00 star(s) 5 ratings
Share this vehicle
