1991 Mitsubishi Galant VR-4 Vehicle Profile & Build Thread
Street Build
My not so daily driven Galant VR-4. Happy just to have it and don't want to wear it out. No compromise summer/winter fun car.
91 Galant VR-4 76/2000
Ownership Status
Currently Own
Turbo Type
16g
Drivetrain
AWD
Build Type
  1. Street
  2. Drag Race
  3. Showcar
2g exhaust manifold (ported collector and runners) VHT Coated, JMF exhaust manifold heat shield w/ SS Bolts, 4 layer exhaust manifold gasket, Ported Genuine MHI EVOIII 16g Turbo w/VHT coated TurboLab ported Ebay Chinese 7cm2 hotside & Tial 40mm ex wastegate w/ VHT coated ex dump, Victory Performance 2.5" VHT coated tubular SS O2 housing, turbo back custom Buschur 2.5" exhaust/Hi Flo CATCO cat/pre-cat exhaust cutout, custom turbo oil return line, ETS Intercooler and intake kit with EVO 8 399 MAF & Blox filter, heavy duty TB seals, PCV check valve, Jaz Products Vented oil catch can, 1G DSM shifter with momo shift knob, Autometer Vacuum/Boost Gauge, Nordskog oil pressure gauge, Mighty Max Front Facing oil filter housing, EGR Block, HIR 9011 and 9012 bulbs in "new" 93 housings with Lamin-X custom headlight protectors, fog lamp delete, Walbro 255 lph pump, Fuel Pump Rewire, 1200 cc RCI Injectors, Electronic Fuel Pressure Gauge, PVC check valve. EVO8 rear seats (14 lb. weight reduction), NGK Wires, Sony Aftermarket Radio, Alarm with keyless/turbo timer/remote start, VIS rear bumper cover with no rear bumper, CF hood with vents, Whole Car Plastidipped Belize Green, Non-Turbo/Non-Cruise Control cable for weight savings, Black top CAS, rare no sunroof model, Walmart/Everstart 300 CCA lawn and tractor battery 16lbs 15oz.
Mods-Engine
ARP Head Studs, Balance Shafts eliminated, EVO 8 half moon cam seal. Ebay Silicon coolant hoses, SPI oil pan.
15w-50M1
Mods-EMS & Logging
Socketed EPROM ECU with Ostrich V2 emulator,
Stutterbox and Check Engine shift light, using RT Tunerpro for tuning. Palm iiic w/mmcd hardwired into car (charges Palm battery too) Innovate LC-2 Wideband O2 with blue gauge
Mods-Drivetrain
JDM GVR4 trans from Noyan with Redline MT90-MTL EVO style cocktail (MTL-MT90-MTL), XTD Stage 4 Unsprung Clutch/PP and Lightweight Flywheel, SS Clutch line and speed bleeder, 3 bolt LSD Rear (B17) (3.545) with Redline Heavyweight Shockproof, Redline Heavyweight in Transfer Case. Aluminum shifter cable bushings on Transmission side, JNZ Tuning Pedal Rebuild Kit with Bronze Bushing.
Sport Edition F2 (Fox 2) (aka Kosei Fox 2) 16 x 7" wheels (20.8 lbs each) with 225/50 Pirelli P Zero Neros, KYB GR2 struts, Energy Suspension Urethane bushings all around, front and rear, AWS delete, Welded Rear Trailing Arms, 1G DSM steering rack running Dexron 6, stock 15 inch rims with Blizzak Rev01's for winter, RMDSM rear swaybar, Powersport Slotted/Drilled rotors and Powersport Ceramic Brake pads, !brake dust shields, SS brake lines, speed bleeders, BG DOT 4 Brake Fluid, aligned to 1g GSX specs
Parts Wishlist
Hoping to really put a head that I have laying around built by Dale Morss (Bogus SVO) on the car along with Cams I grabbed from my Laser. Then I want to run E-85 on the car.
Specs on the head:
Resurfaced 7 bolt 1gb cylinder head (better cooling than 6 bolt 1g head) with 3 angles on the seat + 2 angles on the valves, back cut valves, factory seats, and 6t valves, 1100 BC Springs, Viton Blue seals, oil port mod, and cc'd at 7.6:1
The cams are:
Crower 272's (not Brian Crower) Stage 2 p/n 64413-2
Background
Purchased this car back in 09. It mostly sits all the time. It gets driven once per week to keep things fresh.
I plan to run this at the 1/8th mile once the local track is completely built. I think that this is a perfect car for the 1/8th with it's poor aerodynamics, stutterbox, and longer 1st gear.
Galant VR-4
4gfun
Rating
5.00 star(s) 1 ratings
More in Galant VR-4
More from 4gfun
Share this vehicle
