1992 Mitsubishi Eclipse GSX Vehicle Profile & Build Thread
1GB Mitsubishi Eclipse GSX - 6/4 bolt
1GB Mitsubishi Eclipse GSX 6/4 Bolt
Ownership Status
Currently Own
Turbo Type
16g
Build Type
  1. Street
Fuel :
• Rewired EVO IX Fuel Pump
• EVO IX 560cc Fuel Injectors
Engine:
• SuperTech valve seals
• Cometic MLS head gasket 1.3mm
• ARP head studs
• NPR Piston rings
Drivetrain:
• Exedy Stage 1 - Organic clutch
• Welded pedal assembly with Custom Bronze bushings
• Solid shifter linkage bushings
• Copper clutch line, deleted clutch slave cylinder restrictor
Intake:
• Injen hard intake pipe
• SIMOTA air filter
• 2G MAS
• GReddy catch can
• Additional check valve by factory PCV
Intercooler:
• W2A intercooler
• Bosch Cobra water pump
Turbo & Exhaust:
• Turbo-back 3" SS exhaust
• EVO III 16G - Ported and with turbo blanket on it
• 2G Exhaust manifold - Ported and heat-wrapped
Cooling:
• 1.1 Bar Hyundai radiator cap
• Koyo radiator
• Hood spacers
Brakes:
• 2 Piston Caliper from 2G AWD DSM
• DBA 4425 Slotted Brake Rotors - 276mm
• HAWK HP+ High Performance Street Pads
• Goodridge Steel braided brake lines
• Motul RBF 600 fluid
• ABS delete
Wheel/tire:
• FORGED BBS RG-F wheels - powder coated gold
• Dunlop Sport BluResponse tires
Suspension:
• Eibach lowering springs
• Front strut bar
Interior:
• MOMO Competition steering wheel
Other:
• Removed: EGR, Charcoal canister, unnecessary vacuum lines
• Battery relocated to the trunk
• ABS Delete with copper lines and brass tees
Mods-EMS & Logging
• EVO 8 ECU - tephra 7
• EVO knock sensor
• STACK Boost gauge
• Custom EGT sensor
• Custom IAT sensor
• Custom Boost gauge
• Innovate MTX-L wideband
Parts Wishlist
- HX35 with BEP housing
- Forged internals
- Decent suspension
Background
Purchased in the begging of 2015 from my father's friend.
Car has been sitting in one place for over 10 years, trying to bring it back to life.
It is a 1GB AWD DSM, "1992.5" - 6 bolt motor, with factory 4-bolt rear and LSD.
Fully loaded with leather interior, A/C, power windows, power mirrors and so on.
1G DSM
Marcel
More in 1G DSM
Share this vehicle
