- Ownership Status
- Currently Own
- Year
- 1992
- Model/Trim
- Mitsubishi Eclipse GSX
- Turbo Type
- 16g
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- Fuel :
• Rewired EVO IX Fuel Pump
• EVO IX 560cc Fuel Injectors
Engine:
• SuperTech valve seals
• Cometic MLS head gasket 1.3mm
• ARP head studs
• NPR Piston rings
Drivetrain:
• Exedy Stage 1 - Organic clutch
• Welded pedal assembly with Custom Bronze bushings
• Solid shifter linkage bushings
• Copper clutch line, deleted clutch slave cylinder restrictor
Intake:
• Injen hard intake pipe
• SIMOTA air filter
• 2G MAS
• GReddy catch can
• Additional check valve by factory PCV
Intercooler:
• W2A intercooler
• Bosch Cobra water pump
Turbo & Exhaust:
• Turbo-back 3" SS exhaust
• EVO III 16G - Ported and with turbo blanket on it
• 2G Exhaust manifold - Ported and heat-wrapped
Cooling:
• 1.1 Bar Hyundai radiator cap
• Koyo radiator
• Hood spacers
Brakes:
• 2 Piston Caliper from 2G AWD DSM
• DBA 4425 Slotted Brake Rotors - 276mm
• HAWK HP+ High Performance Street Pads
• Goodridge Steel braided brake lines
• Motul RBF 600 fluid
• ABS delete
Wheel/tire:
• FORGED BBS RG-F wheels - powder coated gold
• Dunlop Sport BluResponse tires
Suspension:
• Eibach lowering springs
• Front strut bar
Interior:
• MOMO Competition steering wheel
Other:
• Removed: EGR, Charcoal canister, unnecessary vacuum lines
• Battery relocated to the trunk
• ABS Delete with copper lines and brass tees
- Mods-EMS & Logging
- • EVO 8 ECU - tephra 7
• EVO knock sensor
• STACK Boost gauge
• Custom EGT sensor
• Custom IAT sensor
• Custom Boost gauge
• Innovate MTX-L wideband
- Parts Wishlist
- - HX35 with BEP housing
- Forged internals
- Decent suspension
- Background
- Purchased in the begging of 2015 from my father's friend.
Car has been sitting in one place for over 10 years, trying to bring it back to life.
It is a 1GB AWD DSM, "1992.5" - 6 bolt motor, with factory 4-bolt rear and LSD.
Fully loaded with leather interior, A/C, power windows, power mirrors and so on.
