1997 GST
- Ownership Status
- Currently Own
- Year
- 1997
- Model/Trim
- Mitsubishi Eclipse GST
- Drivetrain
- FWD
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- FP Race Manifold
ARP exhaust manifold bolts/studs
Holset HX35 Turbo w/ BEP turbine housing
Punishment Racing FMIC
Greddy RS BOV
EVO III intake manifold
Non turbo 1g 60mm TB
APEXi GT downpipe
APEXi N1 cat-back
non-cruise throttle cable
Emissions removed
Fuel:
fuelab AFPR w/ gauge
wally 450 pump rewired
FIC 1250cc injectors
STM E85 rated -6an Teflon fuel line (tank to rail)
Weldon fuel filter
Stock feed line converted to return line
Cooling:
Mishimoto Race Radiator
Mishimoto High flow radiator fan
Mishimoto slim line AC fan
Radiator fan rewired to toggle switch
- Mods-Engine
- Kotzur Racing built shortblock
91 TSi 6 Bolt block
CP Carillo 9.0:1 Pistons
Eagle H-Beams
Stock crank
Kings XP Bearings
ARP Mainstuds
line honed and balanced.
ACT Lightweight flywheel
SS oil pan bolts
OEM stubby shaft B/S delete
BogusSVO oil passageway porting
Kotzur Racing built cylinder head
97 GST Head
Stock valves
bronze guides
GSC valve stem seals
EVO 8 Springs
EVO 8 Retainers
GSC zero-tick lifters
BC 272/272 camshafts
BogusSVO head oil port mod
Held together with a Fel-Pro composite HG and ARP headstuds
- Mods-EMS & Logging
- AEM UEGO Wideband wired into ECU as rear O2
Autometer z series 30-0-30 boost gauge
ECMlink V3
GM style 4 bar MAP sensor and AIT sensor, will be running Speed Density
- Mods-Drivetrain
- Megan racing short throw shifter
Energy Suspension shifter base bushings
- Mods-Handling
- Eibach pro-kit springs
Tokico illuminia shocks
RM Rear sway bar
Nitto Motivo 225/45ZR17 94W
5zigen fn01rc 17x8
Mitsubishi Evo VIII Recaro seats w/ custom Wedge brackets
DC Sports rear strut bar
Momo Prototipo Steering wheel w/ NRG short hub & gen 2.0 quick release
Full Prothane rear bushings
GSX dual piston calipers
Hawk HPS front brake pads
Powerslot front rotors
- Background
- Bought it almost bone stock.
