dherron
- 87
- 4
- Jun 12, 2004
Uhrichsville,
Ohio
With the recent purchase of the dyno at my shop, I am planning on doing some heavy research at the abuse of my own car.
I am very impressed with the HX35 and i intend to push it to the max in its stock form.
Turbo of test will be 8blade, 56mm ind, 82mm exd. With 12cm wastegated exhaust housing.
First test setup will be as followed.
1990 Awd Talon
2.0l block
8.8:1 Comp Wiseco pistons
Eagle Rods
Forged lightened crankshaft
Stock oiling system
Kelford TX-280 Camshafts
Custom Cylinder Head (Fox Lake CNC Port, Dan Herron Custom Valves with 5.5mm Stems, Dan Herron Custom Valve guides, Dan Herron finish port work and valve job. 315cfm @ .500 Lift!)
JMF Drag intake
JMF Top Mount Divided T3 exhaust manifold.
I plan on running the setup on VP Racing CHP Fuel, e85 and alcohol.
Hope to have results within the next few weeks.
1990 Awd Talon
2.0l block
Eagle Rods
Stock oiling system
JMF Drag intake
I will be very interested in hearing your results.
, but he set the pave of D series engine tuning. Now aftermarket companies are following and setting up parts for the soo soo slow honda d series engine. Oh this was back in 2002. Trial and error is the base of everything we research. I'm pretty sure back in the 80s V8 guys were saying its a waste of money to mod that ching chong japanese 4g63t 4banger. HELL I'm pretty sure people said the same thing when the first person put a HOLSET diesel turbo on our engines.
