~laser_craver~
- 470
- 2
- Jan 16, 2003
Montesano,
Washington
Ok recently my brother aquired a complete cryo setup and doesnt want it... But afford to pawn it off to me cheap. My question is how much of a gain will i see with this? Or how much more boost could i run with it? I know what it does and how it works im just curios as to how much more can i get outta my car with this? if not much its still worth it considering how much more it lowers iat and knock etc.
, then a stainless braided line into the engine compartment to a solenoid mounted onto the side of one of my charge pipes (right after the intercooler) then inside the charge pipe is a little aluminum sphere type thing thats hollow and the co2 flows threw that when i push the button then out the other side of the charge pipe then out throw another 3 feet of stainless braided line with a sprayer/purge type nozzle on the end of it. So i was think of mounting the purge nozzle just above the intercooler so that when i am running co2 thru the intake i will also be spraying co2 on the intercooler!
I think i might just give it a try and see how it turns out.... Continue discussing it ###
