| Problem Diagnosis Can't figure out the problem? Does the question not fit in one of the other tech forums? New Members can post here. |
01-04-2005, 02:11 PM
#1 (permalink)
Proven Member
Can't find the right crush washers [Merged 7-8] washer copper aluminum
Okay I need to replace the crusher washers on the oil feed line to the turbo, its leaking. But i can't find them anywhere? Where should I look or how can I fix the leak?
____________________________
James
Offline
01-04-2005, 02:38 PM
#2 (permalink)
DSM Wiseman
Region: Tri State
(2) 12mm Copper Crush washer @ $1ea
http://www.slowboyracing.com/shop.php?sid=&cat=1063
prol have to pay $6+ shipping though
-John
1990 TSI-AWD (orig owner)
Offline
01-04-2005, 04:07 PM
#3 (permalink)
Proven Member
lol..ya I hear the shipping part..now would it just be better to get new lines? I've tryed finding some..but they all seem for just "upgraded" turbos??? But I'll look at slowboy.
James
Offline
01-04-2005, 07:27 PM
#4 (permalink)
Proven Member
Go to any mitsubishi dealer (or even a chrysler dealer if you feel like raising hell) and ask them for
MF660063 (head side of feed line on head)
MF660064 (turbo side of feed line for turbo)
Later
Arnie
Offline
01-04-2005, 08:22 PM
#5 (permalink)
Moderator
A real hardware store or auto parts should have a box full of assorted sizes.
Offline
01-05-2005, 08:54 AM
#6 (permalink)
DSM Wiseman
Region: Tri State
Quote:
My Local Parts+ has one of those pretty plastic cases full of asst'd Std Size copper crush washers on their $10 rack. Though no metric
Have also noticed most of the chain auto parts stores are going to the pre-packaged assortments.. phasing out the "grab-box". Still very limited in metric sizes :thumbdown
-John
Offline
03-10-2005, 03:23 PM
#7 (permalink)
Proven Member
Crush washers...
Ok i've been to 3 different dealerships and none of them have the crush washers for the oil return line. I would have to wait a week before any could be in. I need to put on my new line tonight so I can drive my car out of town this weekend. I can't find them at a O'Reilys, Napa, or Advanced. They all have brake copper washers but all are like 14 mm. Where can i get them at and waht size will work for me? I hear ppl use electrical wire terminals but where do they get them and what size? for 12g, 10g, or 14g wire?
for 14b turbo return line
please help
TIA
Offline
03-10-2005, 09:22 PM
#8 (permalink)
Proven Member
i personally don't know exactly what size guage you are gonna be looking for, but i know some auto stores sell just the ring terminals like the ones you are looking seperately, so if you can take the bolt with you and try and match it up with what fits best.
Offline
03-10-2005, 10:52 PM
#9 (permalink)
Moderator
Region: Tri State
If I remember correctly the only place I found them was the dealer, special ordered $2.50 each. :thumbdown This time around I'm going to see if I can get away with thread sealant and pack the bolt with rtv after tighten down.
Offline
03-11-2005, 08:41 AM
#10 (permalink)
Proven Member
well thanks for the replys but this is the way i had to end of doing it. I went to my local ace hardware and bought 4 copper flat washers. drilled the center out just barely a hair so they would go over the bolt. snug and not loose over the bolt. so then i just coated the 'mother' with copper RTV and hopefully that will work...so far no leaks but havent ran the car more than 10 miles...  anyways thanks for the help...the gaskets on before were a pain too..then trying to remount the oil line ....god...i will never buy a turbo car again...j/k
Offline
03-11-2005, 06:42 PM
#11 (permalink)
Proven Member
Region: Midwest
Just for info.-You may be able to find them in small packages at auto parts stores. I couldn't find a package of the size I needed, so I found a package with a selection of various sizes that had a couple of the correct size washers.
Offline
03-11-2005, 06:49 PM
#12 (permalink)
Proven Member
I bought a set of crush washers from the dealer like a year ago for a turbo install but just ended up reusing the old ones. Twice. From what I've seen, they don't usually go bad.
J Doug
Offline
03-12-2005, 03:13 AM
#13 (permalink)
Moderator
Quote:
Those may work, but be aware that crush washers are annealed, while washers are hardened. You want the annealed (softened) washers next time. Ring terminals are suitably soft.
Offline
04-02-2005, 04:16 PM
#14 (permalink)
Proven Member
help!! need crush washers
hey guys the idoit who put on my turbo beofre me ruined the crushwashers now the leak at both end of the oil suppy line. really bad about a qt every 1000 mi so i need to replace then bhut i dont have a stock turbo does that matter? could i just go to misti to get them? any response welcome thanks oh yea i have a evoIII 16 g in there
Offline
04-02-2005, 06:43 PM
#15 (permalink)
Proven Member
I dont think you should call anyone an idiot when you can string together three words in a row correctly spelled. But anyways, you can use the same size crush washers. Or go to Advance auto since tomorrow is sunday and they sell them also.
Good luck
Mike
Offline
04-02-2005, 06:51 PM
#16 (permalink)
New Member
slow boy racing sells them
Offline
04-03-2005, 05:19 PM
#17 (permalink)
Proven Member
sorry about the spelling but i made the post when i was wasted, anyways thanks for the responses
Offline
04-03-2005, 05:48 PM
#18 (permalink)
Proven Member
Region: Midwest
Here's a list of mitsu part numbers that has the parts you need on it. http://www.phobia.net/~dsm4sale/partslist.txt It'll be quicker, and probably cheaper to get them from a dealer, than having one of the vendors send you some.
Offline
04-04-2005, 09:42 PM
#19 (permalink)
New Member
can i ask how he ruined them?
Offline
04-11-2005, 10:53 AM
#20 (permalink)
Proven Member
Region: Midwest
If you re-use them, sometimes they will leak, because they won't "crush" any longer, since they've already been flattened out.
Offline
04-11-2005, 12:14 PM
#21 (permalink)
Moderator
Region: Midwest
The crush washers are 12mm. Aluminum ones work just as well as copper.
-Paul Volk-
'99 GSX
'91 TSI
Offline
04-11-2005, 02:13 PM
#22 (permalink)
Moderator
Region: Tri State
Quote:
Almost always.
I don't think the guy before you messed it up, you shouldn't re-use crush washers period.
Offline
