ideal o2 voltage and timing?
o2 voltage depends on the mods.
With no knock I get timing under wot 1st gear thru 3rd between 20~24 degrees (per my logger... base timing stock).
I highly doubt your fuel system can handle your mods. Do you have a datalogger? What does your a/f ratio look like thru a full 3rd gear pull?
through a full 3rd gear pull i am getting about .78-.80v from the o2 sensor. and i am getting about 16-21 degrees advance timing.
Is it dropping off as the rpms increase?
O2 voltages aren't much to tune by but I'd think with the stock IC you should be aiming for around 0.90~0.92V.
Do you have a datalogger? If so what are your knock sums like?
yes i have a datalogger, but it doesnt read knock sums(or at least i havent found out how to yet). the readings stay pretty constant through the rpm range(they actually get a tad higher at higher rpm).
btw i have the "interacq" logger
