Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 4G63 DSM Tech > Tuning & Engine Management
Tuning & Engine Management EPROMS, ECU, MAF, knock, EGT, wideband, datalogging, fuel trims, etc. Read this Forum's Strict Guidelines.
Reply
LinkBack Thread Tools
Old 09-27-2003, 05:23 PM   #1 (permalink)
Proven Member
Classifieds Rating: (0)
Reputation: boostineclipse is an unknown
Can you guys look at this log.
Wondering if you guys can look at this log and tell me what you think of it. New to tuning/datalogging.
RPM:6968
Timing:19 Deg
O2 1,Bank 1:.96v 0%
O2 2,Bank 2: 1.0v 0%
RPM:7136
Tming:20 Deg
O2 1,Bank 1:.96v 0%
02 2,Bank 2:1.0v 0%
____________________________
Shaun
Offline
Related Auctions
Sponsored Links
Old 09-27-2003, 05:33 PM   #2 (permalink)
Unverified Email Address
Reputation: Trctnless is an unknown
Thats pretty much what your looking for.. Nice advance...my 2G does the same in 2,3rd gear pulls. (when its cool outside ) Log your airflows next time. what boost? stock turbo?? Thats coming up from like 12deg!5500 right..?
Offline
Old 09-27-2003, 06:00 PM   #3 (permalink)
Proven Member
Was at 16psi, stock turbo. I wanted to log and see how everything was before I actually started to put on all the things I have lyin here, 650s,255lph,turbo,fmic..etc. New to tuning so want to learn as much as possible. I don't want to go in blind..throw everything I have on and THEN learn to tune. Might mess somethings up.
Shaun
Offline
Old 09-27-2003, 08:11 PM   #4 (permalink)
Proven Member
Reputation: Mike 99GSX is an unknown
Praise the lord!!!!! Finally somebody out there that bought a logger as his/her first mod All of my complaining has finally paid off
-Mike
Offline
Old 09-27-2003, 09:25 PM   #5 (permalink)
Proven Member
Haha..yes Mike it was all you, you made me a better tuner
Shaun
Offline
Old 09-28-2003, 07:03 PM   #6 (permalink)
Well... 650s,255lph,turbo,fmic <<<< That should do the trick! with some fuel control. (MAFT?SAFC) Props for your 'Path to date" Just do yourself a favor and install one thing at a time, perhaps starting with the fuel pump, then turbo, (boost limit yourself for a while... then FMIC, then injectors ... That way your not changing EVERYTHING at once and having to diagnose 4 new systems at once right?
Offline
Old 09-29-2003, 10:58 PM   #7 (permalink)
Proven Member
True, I am ###### gonna do that. I have a SAFC-II installed. I am goin on vacation here in a couple of days so I'll have to start when I get back!
Shaun
Offline
Old 10-06-2003, 06:10 AM   #8 (permalink)
DSM Wiseman
dave99gst's Avatar
Classifieds Rating: (29)
good way to go
Offline
Old 10-09-2003, 01:52 AM   #9 (permalink)
Proven Member
Reputation: truwarrior is more helpful than not
You look rich, I was down to .90 on my o2 at 5500 rpms but I guess that's when the t25 runs out of air. I wasn't able to get it any higher then 5500 to see if the o2s would have increased, was running out of road on a 3rd gear pull.
Offline
Old 10-09-2003, 01:57 AM   #10 (permalink)
Proven Member
rpm timing 02
2136 26 0.28
2269 14 0.92
2445 8 0.92
2675 4 0.96
2933 4 0.94
3187 7 0.96
3441 7 0.96
3699 6 0.96
3964 8 0.96
4226 9 0.96
4511 9 0.94
4789 9 0.94
5035 10 0.92
5273 11 0.92
5496 12 0.92
5640 14 0.9
There is my log. My mods at the time were: rsr full exhaust, intake, uip, 1G bov. No boost controller but was boosting around 16-17 psi.
Needless to say I bought a MBC and turned the boost down to 15 psi but haven't made another run yet.
Offline
Old 10-15-2003, 08:04 PM   #11 (permalink)
Proven Member
Classifieds Rating: (3)
Reputation: FASTFWD is an unknown
boostineclipse, nice timing at the top, especially if you're on that piss poor wanna-be gas over there in cali. what rpm/speed did you start at, when you made that log? with my logs, i usually dip into the 3-4 degree timing range, with a stomp on the gas after cruising steadily in 3rd at approx. 3k rpms. at the very top of 3rd, i usually end up w/ 22 degrees of timing (sometimes 23, but never more.. and this is in florida's hot and humid weather).
here are some pics of my logs.. here are the graph portions.. the other numerical screen contains the entire log, ie, engine speed, timing, air flow (the most that i've hit has been 26.3 lbs/min), and o2 voltage (usually .92 at the end of the run)..
Offline
Old 10-15-2003, 09:14 PM   #12 (permalink)
Proven Member
Yeah..I'm on the crap they call gas out here. That was a third gear pull, I start out about the same 2500-3000 when I mash it.
I have to get a nice mount like that. Where did you get yours? I saw a few on ebay I think
Shaun
Offline
Old 10-25-2003, 07:25 AM   #13 (permalink)
Proven Member
Reputation: td06hkiko is an unknown
Can you check out my LOG??? First time logging....
Another Question... How do you Tune for timing Advance?? Do you have to richen it up or lean it out some? Please help. Dont wanna hurt my Motor.
16-17 psi
rpm-6760
timing- 13deg
o2, bank 1: 0.96v
airtemp- 107degf
specs: 20g td06h
660CC denso
SAFC
FMIC
N1
Thanks...
Offline
Old 10-25-2003, 07:26 AM   #14 (permalink)
Proven Member
oH that was 3rd gear pull and egt's were 1600degf
Offline
Old 11-05-2003, 12:03 PM   #15 (permalink)
Proven Member
Reputation: sqhopeful is an unknown
Quote:
Originally posted by td06hkiko
16-17 psi
rpm-6760
timing- 13deg
o2, bank 1: 0.96v
airtemp- 107degf
specs: 20g td06h
660CC denso
SAFC
FMIC
N1
Thanks...
your o2's look right, but your timing is low, most likly knocking some. find out where you timing advance stopped and start adding fuel there.
Offline
Old 11-06-2003, 02:43 AM   #16 (permalink)
Proven Member
Does your timing climb straight up ro does it go up and down. Kinda like 3, 5, 8, 6, 8, 10, 11, 13?
If it dips I've been told it usually means your knocking and timing is getting pulled. Then you would have to more fuel or turn down the boost.
Offline
Old 11-24-2003, 09:07 AM   #17 (permalink)
Proven Member
Thumbs up timing?
YEAH MY timing climbs to 13 at the top of 3rd. I think I should add more fuel. Get more timing. Or where it starts dipping. This is what it looks like.
5,8, 9, 10, 12, 13 needs more fuel right? am I looking for 16-18 deg's at the top of my powerband??
Offline
Old 11-25-2003, 02:19 AM   #18 (permalink)
Proven Member
Reputation: Larry L is an unknown
rpm timing 02
2136 26 0.28
2269 14 0.92
2445 8 0.92
2675 4 0.96
2933 4 0.94
3187 7 0.96
3441 7 0.96
3699 6 0.96
3964 8 0.96
4226 9 0.96
4511 9 0.94
4789 9 0.94
5035 10 0.92
5273 11 0.92
5496 12 0.92
5640 14 0.9
Hey, it was my impression that anything under .93v is considered lean?? Am I right? If so than aren't you running lean up top? Just a question!
Offline
Old 11-25-2003, 11:14 AM   #19 (permalink)
Proven Member
Yeah thats what my log looks like. My O2's were:
.94 up to red. I am still going to install the 660's some time this month.
Quote:
Offline
Old 11-30-2003, 11:31 AM   #20 (permalink)
Proven Member
2G-specific finally dialed in denso 660's FRom Prostreet
rpm: 6844
timing: 18
O2bank1 1.00
17psi
91octane
Offline
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Page generated in 0.25928712 seconds (78.16% PHP - 21.84% MySQL) with 9 queries
