Mike 99GSX
- 650
- 2
- Mar 31, 2003
Columbus,
My mods are accurate in my profile. I went to the dyno yesterday and got my topend of my setup tuned successfully at 22 PSI. I have reletively slow spoolup though and have some questions about how to make it faster. Here's what I think I understand, correct me if I'm wrong. If I had a standalone and complete control, the way you improve spoolup is by leaning out the fuel and retarding the timing. I'm seeing full boost at 4800 which I know isn't great for a 50 trim with a .63 A/R. I'm running a VPC/GCC. The VPC gain is at 0. The GCC settings are 700= -4, 2400= 0, 4100= +2, 5800= +6, 7500= +8. When I logged the 3rd gear pulls, I have crazy high timing advance during the spoolup (like 25-30 degrees). Is there anything I can try with the lower 3 GCC settings to make the timing retard which would help the turbo spool faster? I made 395HP at 22 PSI with an AFR of 12.5. I'm pretty happy with those numbers on my stock 2g motor. Now if I can just get the spoolup going a little better, I should be in good shape.
