When is it time to upgrade to an A-FPR?
mitsugsx95
707
2
Sep 27, 2002
-, Illinois
I am just wondering when it would be a good time to relpace the stock FPR with an adjustable one? I have a 190lph pump, 550's, and an SAFC for fuel mods. Is it even worth upgrading to a AFPR or is the stock one fine? Thanks.
Wouldn't hurt to do it now. I speak as the victim of having a stock FPR fail... :) You're probably OK with the 190lph though. It's a VERY good idea to upgrade if you had a 255lph. If you get a Supra pump, then you better upgrade or you're just asking for problems :)
You don't need one.
You need an AFPR whenever you're running enough boost to get the fuel pressure over about 70 psi, or when you have a pump big enough to overrun the fpr (255lph, Supra).
....Kyle T.
ok well i am fixin to upgrade fuel. i am gonna get a 255lph a set of 580's and a translator. what is a good (fairly inexpensive) fpr for this set up? cuz the 255 will over-run the stock fpr. any help is greatly appriciated.:thumb:
DSM Motorsports has everything you will need. You can also peice together all the parts needed from Summit Racing and a Billet -6AN Fuel Rail Adapter from dsm motorsports. Take a look at the VFAQ's and search here and dsmtalk for PLENTY of threads on this subject.
