explain this log!!
posting numbers will be a lot easier to read.
You are getting knock right when you floor it goes lean until your ecu can adjust.
here one of my logs. you can see at the beginning knock count is higher.
RPM Knock Timing O2 Inj P/W TPS Coolant
4156 0 28 0.84 8.462 80 192
4250 0 27 0.84 10 86 192
4312 7 24 0.84 12.051 88 192
4438 13 18 0.86 14.103 91 192
4500 12 17 0.88 14.615 92 192
4594 12 17 0.88 14.872 92 192
4625 12 17 0.88 14.872 92 192
4688 11 18 0.88 14.615 92 192
4750 11 18 0.88 14.872 92 192
4844 11 18 0.88 14.872 92 192
4938 11 18 0.88 14.872 92 192
4969 11 18 0.88 14.872 92 192
4969 10 18 0.88 14.872 92 192
5188 10 18 0.88 14.872 92 192
5156 10 18 0.88 14.872 92 192
5188 11 19 0.88 15.128 92 192
5281 10 19 0.88 15.128 92 192
5219 10 18 0.88 15.385 92 192
5469 10 19 0.88 15.641 93 192
5531 10 19 0.88 15.641 93 192
5438 10 20 0.88 15.641 93 192
5656 9 22 0.88 15.641 93 192
5594 9 21 0.88 15.897 93 192
5656 9 21 0.88 15.897 93 192
5719 10 21 0.88 15.641 93 192
5812 10 21 0.88 15.897 93 192
5688 9 23 0.88 15.897 93 192
5781 9 23 0.88 15.641 93 192
5969 9 23 0.88 15.641 93 192
5938 9 24 0.88 15.385 93 192
6000 9 24 0.88 15.641 93 192
5969 8 25 0.86 15.385 93 192
5969 8 25 0.88 15.385 93 192
6125 8 23 0.86 15.385 93 192
6094 8 24 0.86 15.128 93 192
6094 9 24 0.86 15.128 93 192
6156 9 23 0.86 14.872 94 192
6281 8 23 0.86 14.872 94 192
6406 8 23 0.86 14.615 94 192
6375 8 24 0.86 14.615 94 192
6438 8 23 0.86 14.103 94 192
6375 8 23 0.86 14.359 94 192
6594 7 24 0.86 14.103 94 192
6594 7 21 0.86 13.846 94 192
6594 7 23 0.86 13.846 95 192
6719 7 23 0.86 13.846 95 192
6625 7 21 0.86 13.59 95 192
6781 6 22 0.86 13.59 96 192
6938 6 24 0.86 13.59 96 192
6844 6 22 0.86 13.59 96 192
6750 6 21 0.86 13.333 96 192
7125 6 21 0.86 13.333 96 192
6844 5 22 0.86 13.333 96 192
7000 5 21 0.86 13.077 96 192
6969 5 21 0.86 13.077 96 192
7094 5 21 0.86 13.077 96 192
7062 5 21 0.86 12.821 96 192
7062 4 21 0.86 12.308 28 192
