adjusting afc
droptopgst
270
Oct 1, 2002
Myrtle Beach, South Carolina
to set the low setting on the afc do i just make sure my LTFT is 0 or close to it, then its done or shoudl I look for something else?
Now what do you guys suggest i do to set the high setting on the afc? I have an A/T so what gear should i use 2nd? any pointers or tips?
My mods
TDO5 18G TURBO (ported and clipped)
34 mm WASTE GATE
APR FMIC
255 FP
AFPR
AFC
660 INJECTORS
ATR 3" TURBO BACK EXHAUST
HIGH FLOW CAT
BOOST CONTROLLER
INTAKE
GREDDY ICP
TYPE S BOV
NGK PLUGS 1 colder
POCKET LOGGER
Ewww, 18g.:barf:
You want to set the low throttle maps so that the sum of the STFT and the LTFT is 0%. Then you want to start out by setting the high map to whatever the higher rpm's (4k or so) on the low map are set to. Then tune for timing.
Just use the highest gear that you possibly can, 3rd would be better, but if you just can't do it saftely, then you have no choice but to use second.
http://www.dsmtuners.com/forums/showthread.php?s=&threadid=58403
......Kyle T.
93 TSi AWD "TURBO4"
14b - 12.8 @ 108
