Coldandafraid
- 1,147
- 3
- Mar 1, 2003
Edmonton,
Well, after a week of cautious experimentation with the afc settings I have finally found out why I was getting 0.04v O2 at WOT. It turns out, that if my fuel is perfectly tuned to my boost, I get good timing and O2 readings, however, if I am just a couple percent above what it should be, instead of my O2 readings going up to 1.0 v, it actually goes straight down to 0.04v. So, basically, if I am too rich, I get nothing on the O2 reading.... which caused me to add more fuel at first, making it worse... so I added more, and I got rich knock, timing when down, car started hesitating... so, I got brave and took all the fuel away, and I got real knock! So, I added bit by bit till my timing came back. However, its still very hard to get it exactly right...
