Yet another AFC question
snake679
166
Nov 23, 2002
I just put my 2G mas in my 90 talon, can anybody help me with some afc settings that will get the car running decent until my datalogger gets here????? My profile mods are accurate, and i have an air/fuel and pyrometer if it helps any. Thanks a ton!!
it shoudl run fine anyhow...try bumping th fuel about 10% across both boards and see how she does...
Is there a specific problem? I know its weird but Iv edone 2 2G swap's before and both just needed a little tuning. In between each adjustment you make let the car adjust to what you are doing. It seemed for me I was reacting to quickly and not giving enough time. Basically the 2G will flow ~5-15% more air depending on what shape the 1G maf was in and the adjustment screw on each... so try 10% out for a day or so of normal driving conditions and report back!
