Apexi99
- 113
- Nov 21, 2002
"an egt WILL NOT tell you if you are running rich or lean. it measures exhaust gas temperature ONLY. from there you need to gather other info like fuel pressure and current A/F ratio thru a wideband or your own STOCK O2 SENSOR to determine if the hotter temps indicate a ""lean condition "" OR more importantly a restrictive turbo and/or exhaust system. there is alot more to it than saying hey i am running 1500 degrees let me increase fuel thru the injectors.. it may make it worse.!!"
"EGT readings WILL NOT give you a proper A/F ratio. NO MATTER WHAT.
there is no need to get into it about false lean readings and such. plain and simple it is only a measurement of EXHAUST TEMP WHICH WILL GIVE YOU A RELATIVE UNDERSTANDING OF GAS VELOCITY. there is no magic number or chart to look up and say at this temp i am at 12:1.
its a fanatsy. you can only infer with the readings and use OTHER helpful info to determine the efficiancy and validity of those temps. every car , every exhaust , every induction, injection, ignition on every car is different at EVERY COMBUSTION CYCLE. it is impossible to use it as a reference for the proper A/F ratio"
this was quoted from another board...some of it doesnt sound right to me..at all...can some of you guys give your thoughts on it
Let me know, and I'll try to clear up the fuzzies.
