tunerdoc
- 41
- Jan 5, 2003
north kingstown,
Rhode Island
Help I have just installed two Auto meter gauges one Boost the other air fuel. The boost runs in the vacuum until turbo kicks and then heads for 11 lbs. The air fuel goes back and forth rapidly, under boost it goes to rich then goes nuts again??? I want to put aMBV on but not till I can get a handle on this so I have safe perameters.
Can I get help?
Is it a bad gauge?
Ground?
It is tied into the ECU for info
Thanks
Doc
Can I get help?
Is it a bad gauge?
Ground?
Thanks
Doc
that is why the next gauge im getting is the egt that is way more reliable
