1st time logger
genxxxracer
123
Dec 22, 2002
Here is the situation. I just got the pocketlogger and am using the first time after I put in all the stuff.
Heres what I just put in.
ported exhaust manifold
ported 02 with dump tube
frank2 turbo-20g with td06 housing
rre mbc
I have 720 injectors, but havent put them in yet, since I cant get the thing to idle without any boost.
I already had the s-afc and greddy uicp and type s bov. Heres what the log showed when I was trying to get the thing to idle without shutting off.
Time Load RPM timing airflow tps
1.55 60.12 1544 9 3.58 12.18
3.11 67.98 2256 10 6.46 5.11
4.66 76.23 2096 5 6.8 25.54
6.21 76.62 1972 8 3.4 9.04
7.77 60.51 2128 7 4.33 18.07
9.33 65.23 1628 14 5.76 9.82
10.89 68.76 2044 8 4.11 14.93
12.47 60.51 1824 8 3.1 9.82
14.04 61.69 1544 9 3.46 11.79
15.59 61.69 1532 9 3.35 11.79
17.15 61.69 1508 9 3.71 11.79
18.71 61.69 1484 9 3.46 12.18
20.27 64.44 1548 9 3.56 12.18
21.81 50.29 1612 9 4.03 12.18
23.37 38.9 2320 28 3.94 12.18
24.93 39.29 2480 29 3.75 12.18
26.49 45.97 2484 29 3.9 12.18
28.05 44.79 1920 22 3.84 12.57
29.59 44.79 2152 24 3.89 12.57
31.16 44.01 2304 28 4.08 12.57
32.72 54.22 1984 21 3.66 12.57
34.28 43.22 1796 20 3.89 12.57
35.84 53.05 2216 22 3.36 12.57
37.4 53.44 1684 11 2.93 22.4
38.95 53.44 624 4 1 39.69
40.51 0 116 5 0.17 0.39
What should I do with the afc. Start at 0 then lean it out or make it more rich. thanks.
Im sorry I haven't been returning you Brent. Ive been working a lot... Right now I am free so you can call me if you want and Ill come over and help you out as best I can. I gotta work at 1700 though so let me know. Again Im sorry about that, but Ill try and help and see how things are going,
AUstin
602 363 1738
