GReddy e-Manage
GSXTiAl
Jan 4, 2003
Michigan
Can a GReddy e-Manage run solely off a MAP sensor? I read in a forum that you had to use the stock MAF as well, but wouldn't that defeat the purpose?
~Thanks
Yes the GReddy e-Manage system has to use the stock MAF. The reason why you can buy the MAP sensor with it is so that you can tune your fuel and ignition maps, to your boost curve. Not just off RPM and throttle position.
If you want to get rid of you MAF, get a HKS VPC or a standalone
