fuel pumps
MikesDSM
562
Jan 5, 2003
empty, New Jersey
what are your suggestions for a fuel pump? i see a lot of people with walbro's and TT pumps. how's buschur's?
thanks
well nothing yet, in the summer 96-97 tsi awd
this is what i want
hks ss bov
injen intake pipe w/ k&n filter
hks hiper exhaust
buschur downpipe
buschur o2 housing
testpipe
hks turbo timer type-1
turboXS dual stage MBC
unorthodox ultra ss pulley kits
free mods
what type of power can the 255 support.and whats with the rewire ordeal.whats that all about.
Fuel Pump Re-wire
Rewiring the fuel pump with a larger gauge wire can help the stock fuel pump (and aftermarket pumps) maintain higher voltage, resulting in more fuel pressure. The stock wire that runs between the battery and the fuel pump is a bit too small, limiting the voltage to around 10 volts or less at the pump under high boost levels. Adding a larger wire and relay can increase voltage to that of the battery (usually 13-14V), maximizing the fuel pump's output.
apexi super afc,and adjustable fuel pressure regulator.
thanx for the info on the rewire.i never knew what that was all about.learn something new everyday.thanx
i do beleive air fuel controller.
Air Flow Converter.... It takes the signal from the air flow sensor and modifies it to fool the ECU into doing something that you want it to do.
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
