95+ Eclipse and Evo ECU
rm2932
Dec 22, 2002
New Berlin,
I was just wondering if anyone has a wiring diagram of a EVO IV+ as far as for there ECU pinouts.
I was just wondering cause I am interested in HKS part number 4202-RM009 which is a F-Con V Pro wiring Harness for the EVO 4-6 in europe.
If it is compatable then it is possible to buy this harness with a F-Con V Pro and be able to tune like a stand alone ECU that is speed density based but still have the stock ECU run the AIC, Radiator Fans, Etc. This would be just like a DSM Link but be able to run 8 injectors and get rid of the air flow meter. The F-Con V Pro map sensor is good from 66.7kPa`354.6kPa which is good to about 37psi.
Thanks
Ryan
Option pressure sensor
(Super wide range) - Pressure range: 13.3kPa - 400.0kPa and F-CON V Pro, F-CON S
I would look at Evo 1/2/3 instead of IV+ when you have a 95+. Besides, 95+ has higher comp ratio of 8.5 equivalent to Evo 3 and Evo 3 does have a Big16G turbo from the factory.
huh? You just missed the question. This is about running a stand alone engine mangement system that is speed density based. It has nothing to do with compression or anything. None of that matters cause it is a stand alone in which you tune on a 16 X 16 grid.
All I want to know is if the Pinouts are the same between a Evo 4-6 and a 95+ eclipse. If they are you will be able to run a F-Fon V Pro by just buying the harness which is basicly just like a VPC Harness.
Thanks
Ryan
