10-24-2007, 12:48 AM
#1 (permalink)
Proven Member
Region: Mid Atlantic
Those with adjustable cam gears, what are your setting/advise
Those with adjustable cam gears, what are your setting/advise?
Offline
10-24-2007, 01:59 AM
#2 (permalink)
Proven Member
Region: SoCal
a dyno
____________________________
dsmap project leader
Online
10-24-2007, 02:26 AM
#3 (permalink)
Proven Member
Yeah i know, but i wanted to know what are some basics retard/advance on the exhaust/intake, otherwise what are some basic settings that i can get started with and what would be a good point to start with.
I just need a some rough estimate on where to get started...
Advance exhaust does...
Advance intake does...
Retard exhaust does...
Retard intake does...
Offline
10-24-2007, 09:01 AM
#4 (permalink)
Proven Member
Its different for every motor. Depends on if your head or block deck is shaved, what kind of cams you have and all that good stuff.
Brian
Offline
10-24-2007, 10:00 AM
#5 (permalink)
Proven Member
Region: Southwest
Dyno is the only way unless you find someone with your exact set up that has been to the dyno.
Offline
10-24-2007, 10:39 AM
#6 (permalink)
Proven Member
Region: Pacific Northwest
So from this discussion, it seems the adjustable cam gears are worthless without a dyno. Good to know that! They never really tell you any of that when they're trying to sell you those damn things.
Online
10-24-2007, 10:55 AM
#7 (permalink)
DSM Wiseman
Region: Central Canada
Offline
10-24-2007, 01:35 PM
#8 (permalink)
Proven Member
Region: Tri State
What setting do most people use, and why don't alot of DSM's advance intake only?
Offline
11-09-2007, 06:59 PM
#9 (permalink)
Proven Member
Region: Midwest
Mine ended up both set at 0.
Offline
11-10-2007, 06:17 PM
#10 (permalink)
DSM Wiseman
Quote:
Answers to these questions are not relavent to increasing performance. . .
It's just not as popular. Most don't muck w/ 264s. They muck w/ stock cams to get the most out of them. Or they muck w/ 272s which usually yield better spool w/out loosing much top end. . .
Matt
dd '90 GST, Holset H1C
Offline
11-10-2007, 06:21 PM
#11 (permalink)
DSM Wiseman
Quote:
On the contrary, Anyone w/ fp2x cams that retards the exhaust cam about 3 degrees will ALWAYS yield an increase in spool speed and basically have a set of fp3s. As the only difference between fp2x and fp3 is the overlap (exhaust cam timing).
I saw great results retarding my exhaust cam on my fp2X cams regardless of turbo: 60-1, 18g, or small 16g.
Matt
Offline
10-14-2008, 09:02 AM
#12 (permalink)
Proven Member
Region: New England
What if you have an FP1 intake and an FP2 exhaust...would you recomend retarding the exhaust gear 2.5 degrees?
- Alex - White_2g on DSMLink Forums
Offline
10-14-2008, 02:02 PM
#13 (permalink)
DSM Wiseman
Only experimenting can tell for sure. I've had no experience with the fp1/fp2 combo, but they do have the same overlap. Retarding the exhaust cam will help spool speed and when you go to a stroker, this timing will likely be better for the piston velocity.
Matt
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is On
