Simple fuel question
MitsuE95GST
103
May 28, 2002
Sumter, South Carolina
Any of you guys that are running big fuel pumps know how much it rasies your pressure in the line? I know they over flow the stock FPR. What effects does it have on the car?
No. But it does alot, since I just installed a FPR and set the pressure to 42 psi and now I have to add alot of fuel back in at higher rpms were is was originally rich from the FRP overrun.
Later,
Same here the car felt a lot smoother and it was much easier to tune with the addition of the fpr. The 255 I had in their was overrunning the regulator by a lb or two.
Thanks guys, so you guys think an aftermarket FPR is a good idea? What are some good aftermarket FPRs that you guys suggest?
I have an AEM fpr. To install that you have to weld an an fitting to the end of your fuel rail. I think this looks great it is also very easy to adjust and read your fp. There is also the spoolin fpr this is much easier to install but I don’t have an direct experience with it.
Bolt-on,Lowest price,adjusts pressure up or down.
Later,
Well today I was playing with my spare FPR I had for my 2G. I found a way to modify it to flow more fuel, the only problem I have now is if I leave it installed I will be running lean, it is at 39 PSI with the modification. I am going to get a B&M to raise the pressure again back to 43PSI, that should be cheap only 65$ from road race, I already have the B&M fuel guage so I can set it. Thanks for the info guys.
If you any of you would be interested in me doing this mod for you let me know.
If you have a AFC you can add fuel if the base pressure becomes 39psi
Later,
I have an AFC, I guess I could do that, but would'nt that push me closer to fuel cut, and take a couple of cc out of 450s of course I am getting some 550s soon.
Well without and EGT gauge and a logger theres no point in all this anyway. Can't tune w/o them.
Later,
I have the EGT, i'll be getting the Logger on the 5th. Guess I can wait till then.
I would since it is kinda of a Ghetto setup (no offense) you want to be able to log to make sure nothing goes wrong.
Later,
