pocketlogger
crashed97tsi
828
Apr 21, 2002
Bethlehem, Pennsylvania
hi
i've been looking into getting one of these but i have a few questions.
what exactly can you do with it?
is it hard to use?
a 97 talon tsi has eprom right?
any help is greatly appreciated
thanks
A pocketlogger can view and log vital engine functions and look and clear CEL's. Go to Pocketlogger to view the logging parameters. It is very easy to use and log.
No 97's do not have an eeprom ECU.
Later,
nah i don't have a afc. gonna have to get one of those too. is the pocketlogger really worth it? i read somewhere that it doesn't let you change any values, just log data. If that the case then how do you tune the car more when you know you have a problem? Is this where the afc comes in? if so which would you recommend
thanks for the help !!!
You can only log not change values. If you see an issue you use the AFC to add or reduce fuel to get timing up.
Later,
