So i went to the track yesterday and logged a few logs. Can anyone please point out what's wrong with the timing? And for whoever has the ProfecB spec II, I had to turn the gain up to 49% to be able to get a peak boost 18.9psi, is this right? The boost does not hold steady, i saw the boost controller tried to adjust the boost level and the boost went up and down during the run. The end result is a 13.7sec pass with 98mph trap speed.
Please point out if I am running too lean or knock issue, and how to adjust the damn EBC!
Important mods are: 16G, 550cc, 225fuelpump, safcII high setting at around -19~-20, FMIC, boost set @ 19psi and dropped down to 16~17 at 7000rpm.
