fuel system setup
I'm getting my afc in a few days, ###### going to throw on a big t-28 so I was thinking, a 255 pump, and tap some AN fittings on the rail, braided steel lines from the filter to rail then a areomotive fpr then steel lines down to the return hard lines.
trying to keep the stock injectors you think will work??
