Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 4G63 DSM Tech > Tuning & Engine Management
Tuning & Engine Management EPROMS, ECU, MAF, knock, EGT, wideband, datalogging, fuel trims, etc. Read this Forum's Strict Guidelines.
Reply
LinkBack Thread Tools
Old 09-14-2004, 08:18 PM   #1 (permalink)
Proven Member
Region: Midwest
Classifieds Rating: (0)
Reputation: v8killerr1 is more helpful than not
lo throttle with afc
Ok, i've read the tuning guide and searched and I'm kind of confused. For the lo throttle settings do you want the LFLT to be zero or do you want to add the short and long together to equal zero? Also, do you want to free rev and get your base settings then take a drive and get the fuel trims zero while driving or just use the settings that you free reved with. thanks
Offline
[posts] Reply With Quote
Related Auctions
Sponsored Links
Old 09-14-2004, 10:35 PM   #2 (permalink)
DSM Wiseman
Add the STFT and LTFT.
You can free-rev and then drive, or just drive. I just drive.
Offline
Old 09-15-2004, 09:32 PM   #3 (permalink)
Proven Member
Region: Midwest
thanks for the info some people were saying only tune for the ltft so i was a little confused. The car is a crap load faster after i've tuned the lo and hi.
Offline
Old 09-15-2004, 10:50 PM   #4 (permalink)
DSM Wiseman
The LTFT is simply the saved trends from the STFT. If the STFT is rich (or lean, or whatever) for a certain amount of time, then the ECU starts changing the LTFT, and saves it for future use.
In addition, when figuring the injector pulsewidth, the ECU uses the LTFT and the STFT. This means you need to take both into account.
You could get the car tuned using the LTFT only; you would need to tune the LTFT down, drive the car a bunch, adjust based on the LTFT, and repeat. Watching the STFT allows you to predict where the LTFT is going to go in the future, and that way you can simply catch it before it gets too far away from where you want it.
Offline
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Page generated in 0.12354803 seconds (60.73% PHP - 39.27% MySQL) with 9 queries
