TURBOSPYDER
- 143
- Feb 21, 2002
Daly City,
I have a 99 GST and I was wondering which is more important:
Good Timing or Good EGT's
Heres the situation:
EGTS at 850c with timing rising from 10-16 degrees in the top of third.
OR
EGTS at 890c with timing rising from 3-13 degrees in the top of third.
For info on my set up, go to: http://www.turbospyder.dsmpower.com
Unfortunatly I cant tell which AFC setting makes me go faster. Any info on this subject would help.
Thanks in advance.
OR
Thanks in advance.
Hey Put more fuel in.. I wouldn't be running that lean. I bet your getting lots of burn marks on your piston, if not you will be melting soon. I don't recommed going over 900.
