Fuel pump and injectors
Rob
707
Aug 26, 2002
If i install the new fuel pump and injectors with no fuel controller will it run messed up ? what will it do will i need to do anything ?:confused:
Adding just a basic upgraded fuel pump (150lph) should be ok. With larger injectors and/or huge capacity fuel pump, fuel control WILL be necessary. You will need an AFC and Adj. Fuel Pressure Regulator.
Put a 255LPH Walbro in the car on the stock system without pump rewire and it ran just a little rich at idle... Don't upgrade injectors without an AFC, or some sort of fuel management or the car will barely run at all if it'll start. :)
L8R :dsm:
would a 190 be able to support a big 16g later on? when all other supporting mods are in place.
It should support a big 16g fine unless you plan on running insane boost. I don't even know if big 16g will make enough hp to over do that pump. I would say it should be fine though
awesome. damn i'm glad i didn't buy a 255. that would have cost me more money and more problems.
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
