Custom built upper intercooler pipe
LTUDSM
1,802
7
Jun 27, 2005
Morrisville, Pennsylvania
Finally i got a solid Upper intercooler pipe,so no more worries about the leaks through the couplers :p.The pipe was made by KrazyHouse Customs..
I dont like where you have your blow off valve. That gives you no chance to upgrade to a GM Maf in Blow Thru setup
If thats your plan then welded pipes are great.
Agreed. Not every DSM setup consists of a GM MAF. The pipe looks good, bro. I hope you have some solid mounts so that sumbitch doesn't flex during shifts :D
i got a polyurethane mounts..... trying to get boostleak free . but im still havin a leak somewhere,i hear hissing sound,but can't trace a damn leak,rplaced everything ,that is possible: shaft seals,injector seals,new vaC lines,well i got only four of em left (bov,wastegate,boost controller,AFPR). Spe nt over 400 on a pipe to make a couplerless.all the gaskets were replaced..... no exhaust leaks. got the idle tuned ,so it idles smooth.look like no vac leaks,but the hissing noise is pissin me off....:ohdamn: Tommy Any suggestions of where the leak might be commin???
i had a gm maf setup on my 1g.had alot of problems getting the idle right,because it was bouncing from 800 rpms to 1100 rpms. prob bad luck. and right now im venting ### of the Tial,having no issues at all, well accept the rich condition after shifting the gears.... idles smooth,doesn't stall.even if i rev to redline, the rpms drops no lower then 850(thats where i set it, due 272's)
i never tried with ecmlink,maybe they work together really well,but i don't wanna risk and have the same prob as i had before...
Do a boost leak test. My car was pissing vacuum from the middle of my throttle body meaning the top and bottom portions.
i did,but still can't find such a small leak. the pressure from 25 to 0 drops in like 4 minutes. but the leak is so small to be traced down.,tried spraying with a soapy water,didn't see any bubbles comin out....... thats weird...
