08-12-2008, 08:08 PM
#1 (permalink)
Proven Member
Region: Tri State
need help on Timing
does anybody could help me to do a timing belt job,cause im kinda lost on how to tension the tensioner  i need some help ASAP!!!!
Offline
08-13-2008, 09:38 PM
#2 (permalink)
Proven Member
Region: Tri State
anybody????? sorry i know bumping threads are illegal,but i really need help.....
Offline
08-13-2008, 09:40 PM
#3 (permalink)
Proven Member
Region: Southeast
your best bet is to get a professional to do it so nothing is messed up on the car
____________________________
Vega
Offline
08-13-2008, 09:58 PM
#4 (permalink)
DSM Wiseman
Region: Tri State
Are you reusing your tensioner, hence asking about how to tension it? If you're reusing it, you'll want to use a bench vise to compress it. Rotate the handle no more than 1/2 turn, let it sit for 20 seconds, repeat. Make sure you turn the handle s-l-o-w-l-y, otherwise you could damage the tensioner. I would volunteer, but I won't be home until next weekend and I'm not sure if I'd need any of the specialty tools or not (which are not currently with me). But if you're still looking for someone by next weekend, let me know.
Make sure you read over this a few times if you do plan on doing it yourself:
Timing Belt VFAQ (Timing Belt TSB - ENHANCED)
Brian
Offline
08-14-2008, 06:20 PM
#5 (permalink)
Proven Member
Region: Tri State
i did it once,and i reuse it. i put it into bench wise and press it,till i could be able to put a tiny rod into that little hole,but i pressed it fast,not slowly like your saying.... Prob i damaged the auto tensioner
Offline
08-14-2008, 06:43 PM
#6 (permalink)
DSM Wiseman
Region: Tri State
Was it leaking at all, as that'll be a dead giveaway that it's done. I'm not 100% sure how to tell if it's broken though.
Brian
Offline
08-14-2008, 07:17 PM
#7 (permalink)
Proven Member
Region: Southeast
If you're tensioner is the one the car came whith from factory i would just buy a new one.
You will also need this little tool for the tensioner pulley.
2literturbo...
Offline
08-14-2008, 07:29 PM
#8 (permalink)
Proven Member
Region: Tri State
i
i got not even a 1000 miles on my pulleys and auto tensioner.Last time when i did timing job,i probably didn't tight the tensioner pulley and auto tensioner correct.so the Tensioner pulley was hitting something,when the car was idling or driven.so i don't want to do that mistake again,and i need help really bad,i could go to the mechanics,but don't feel paying for a tow truck  ((
does anybody knows about this unit??? Tensioner
Offline
08-14-2008, 07:41 PM
#9 (permalink)
DSM Wiseman
Region: Tri State
Brian
Offline
08-14-2008, 07:46 PM
#10 (permalink)
Proven Member
Region: Tri State
yeaah i just read the whole thing,and ,everybody are sayings that the Oem Auto tensioner is better then this manual one..
Offline
08-14-2008, 07:56 PM
#11 (permalink)
Proven Member
Region: Southeast
Yeah...make sure you stay away from that tensioner you posted you will need to adjust that manually. so that means that you need to pull you're timing cover every 200miles or so till the belt is fully stretched.
Just use your stock one or get an oem replacement.
Take a look at this from (blcknspo0ln)
it's a lot of help.
Pictorial: Installing/Timing a timing belt (6bolt/2g)
2literturbo...
Offline
08-14-2008, 08:43 PM
#12 (permalink)
Proven Member
Region: Tri State
Nice Write up!!! blcknspo0ln
Offline
08-15-2008, 09:20 PM
#13 (permalink)
Proven Member
Region: Tri State
ok ill tryed to do the timing my self again.
the steps how i did are:
took the old timing belt off
took the auto tensioner off
put a new auto tensioner on
put a new timing belt back on
adjusted the cam gears
went down and put the t-belt on a crankshaft sprocket and oil sprocket
loosen the tensioner pulley
push the tensioner pulley as far as i could and torqued the tensioner pulley bolt to 40lbs/f
measure the gap between the auto tensioner rod and the tensioner arm,it was 0.16
is that a right procedure that i did ,or not??
Offline
08-15-2008, 10:22 PM
#14 (permalink)
DSM Wiseman
Region: Tri State
That sounds correct. Did you make sure to turn the motor over 6 times, let it sit for 15-20 minutes, and recheck all the timing marks?
As long as you followed all the steps in the link I gave you in post #4, you should be fine!
Brian
Offline
09-08-2008, 04:49 PM
#15 (permalink)
Proven Member
Region: Tri State
ok guys Bad news,my 3rd cyl bearing melted due of lack lubing  ((( .The othe problem is that i need new crank and a new 6 bolt bare block. Does anybody know a good place where could i get one??? ### i looked in classifieds,dsmtrader,philadelphiadsm,craiglist,ca lled jnz,turbotrix,extremepsi nobody has one  (((( im totally screwed....... Or could i just grab a N/T block,switch my wiseco pistons,eagle rods and new crank. would it work????
Offline
09-08-2008, 11:34 PM
#16 (permalink)
DSM Wiseman
Region: Tri State
Quote:
That sucks  I was glad to see everything worked out as I was scrolling through your thread. Your best bet is to look for an uncut crank and rehone your block, but of course I'd bring it to a machinist to inspect it first.
~Tom
Offline
09-09-2008, 07:27 AM
#17 (permalink)
Proven Member
Region: Tri State
The thing is,that my block is cracked,so when i rebuild the bottom end,i didn't see the crack,but when i put everything back,pour the oil and it was leaking,so i was sad,but then i tryed to put some JB Weld,but it didn't worked out.I read about ,how the guys are building the N/T Blocks and i saw,that their builds were successed. So i think i just go to a Junkyard,get the 4g63 block and will start from there.....  (
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is On
