Login
Go Back   DSMtuners > DSM Forums > DSM Tech > Cylinder Head & Short Block > Stroker Tech
Stroker Tech 4G63 stroker discussions - 2.1L, 2.2L, 2.3L, 2.4L, etc.
Reply
LinkBack Thread Tools
Old 06-08-2009, 07:27 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #1 (permalink)
Proven Member
Tech Posts: 81
Classifieds Rating: 2
Reputation: red97gsx is an unknown
bc280's or fp3x
I have a 2.3 that i built for a street car and have a 2.3 with bc280's. Supporting mods include stage 4 head, 1mm o/s valves, si double ti springs and retainers, balanced rotating assembly, Magnus SMIM, rewired wally 255, etc, etc,etc. I had put a FP3065 with FP race manifold and changed my setup to a new FP 3582HTA with a T3 SLS exhaust manifold and .82 v band a/r with FIC 1050's. I am running pump with meth and am shooting for low 11's and 550+ AWHP on pump with meth. Car will be street driven, not a daily, but not a trailer queen either. Any advice on which is a better cam to go with? If i forgot to add any other necessary info on my build, please let me know.
Thanks,
Advertisement
To browse the forums without the advertisements above, Login/Register
Old 06-12-2009, 03:51 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #2 (permalink)
Proven Member
HIGHPSI4's Avatar
Tech Posts: 447
Photos: 21
Classifieds Rating: 12
Reputation: HIGHPSI4 is pretty helpful and trustworthy
I run the 3x's. I believe you will have better results with the 3x's. As for mine, my car idles like stock at 800 rpm with the BS eliminated so these can be used for all types of set ups.
____________________________
4G64 GT35R FP 3X Cams
View photos of this member's car
Old 06-16-2009, 11:28 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #3 (permalink)
Proven Member
talontsiturbo20's Avatar
Tech Posts: 124
Photos: 7
Classifieds Rating: 3
Reputation: talontsiturbo20 is more helpful than not
I run a 4G64 bottom end with BC280s. I run the same valve train you do. It is VERY lumpy idling anywhere below 1K. I really like the 280s, but I have considered switching to the FP3X's. If you decide to commit to the FP cams, you will need to swap your springs and retainers for FP's package. The SI's do not have enough seat or open pressure to run the FP 3X's.
2.4L: Wiseco's, Eagles, V3
....and more!
Old 06-16-2009, 11:46 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #4 (permalink)
Proven Member
Tech Posts: 166
Classifieds Rating: 0
Reputation: 2slow4utsi is an unknown
Kelford 272s.
Old 06-16-2009, 04:44 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #5 (permalink)
Proven Member
Tech Posts: 81
Quote:
The SI ti double springs won't work with the FP3's?
Old 06-17-2009, 11:19 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #6 (permalink)
Proven Member
Tech Posts: 124
Photos: 7
Quote:
The SIs are not stout enough for the cam profile. FP recommends using nothing but their springs, however I believe there have been a few members using other spring packages that match or are above the spring pressures of the FP set.
....and more!
Old 06-17-2009, 03:15 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #7 (permalink)
Proven Member
dSmgs-T's Avatar
Tech Posts: 339
Photos: 2
Reputation: dSmgs-T is an unknown
i have a 2.3 stroker and got kelford 280's... i have yet to get the car running, but i have heard nothing but good things about them!
Old 06-20-2009, 11:22 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #8 (permalink)
Proven Member
Tech Posts: 81
has anyone used the si doubles with FP3X's with good success?
Old 06-23-2009, 11:54 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #9 (permalink)
Proven Member
Tech Posts: 124
Photos: 7
Maybe you should consider the application:
SI dual valve springs
80 psi on the seat
190 psi @10mm lift
14mm max lift
19mm coil bind
FP3X camshafts:
Be sure to install your springs with 280+lb over the nose. This camshaft has the highest valve acceleration that is allowable with our dual valve springs.
Intake cam lift on the 3X is .430". Now, at .430" lift (=10.92mm) FP recommends valve spring pressure @ 280psi +. If you do the math, SI duals @ 10mm of lift are only @ 190psi. If you consider the spring rate of the SI duals (11lbs/mm), @ 10.92mm of lift the SI duals would be @ 200.12psi. You are about 80psi under the recommended spring pressure @ max valve lift.
....and more!
Old 06-30-2009, 06:03 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #10 (permalink)
Proven Member
Tech Posts: 81
^^^ Thank you for the above information. When spelled out like that, it is very obvious that they will not work together well. Guess i will have to wait a while before proceeding with the cam upgrade.
Reply
Bookmarks
Thread Tools
Similar Threads
Thread Thread Starter Forum Replies Last Post
FP3X on a 2.0L? JeanDSM Cylinder Head & Short Block 5 06-13-2008 12:26 AM
Idling on FP3x cams danl DSM Video Links 1 08-04-2007 03:08 PM
Which valve springs to use with fp3x GILZTSIAWD Cylinder Head & Short Block 28 07-13-2006 01:18 PM
FP3X cams,,,,what do you guys think chuckdog_5 Cylinder Head & Short Block 65 04-11-2006 02:57 PM
» 2010 DSM Calendars
» DSM Mechanics Gloves
» Recent Blog Entries
Seat
by: Spdfreak
Update 4
by: Kevin TSI
Engine shots
by: Spdfreak
Best DEAL ever *Update*
by: 4Motion4g63
2.4 Liter G4CS build thread
by: Atuca
» Recent Tech Threads
Title, Username, & Date
50 trim exhaust housing swap??
by: brtmsx
boost and alarm question
by: 95'RS-T
Big problem need help asap
by: Niteninja01
97 eclipse BOV
by: mitsukid124
1995 eagle talon tsi awd pulling the engine
by: icet34
» Latest Gallery Photo
User 1fast97gsx
» Advertisement
» Current Poll
What will you be buying soon?
DSM Calendar - 36.36%
8 Votes
17 Votes
7 Votes
Total Votes: 22
You may not vote on this poll.
Powered by vBadvanced CMPS CMPS v3.2.1
DSM Forums | Pontiac Solstice/Saturn Sky Forums
© 2009 SPEEDtuners Network, LLC All Rights Reserved
Search Engine Optimization by vBSEO 3.3.1
