90AWDTalon
- 877
- 3
- Jan 5, 2003
Everett,
Washington
Originally posted by kpt4321
However, in a turbo car, it's much better to use manifold pressure for this load reference, which is why I always set the SAFC up with a 3-bar map sensor instead of a throttle input. Start a new thread if you want to discuss that, it's a MUCH better method than using throttle.
I'd like to hear what you have to say about this.
I have an emanage, with support tool and ignition harness. There is an optional pressure sensor for the emanage. With my set up, for my fuel map I get a 16x16 map, throttle vs. rpm. On my timming map I also get a 16x16 map airflow in Hz vs. rpm. With the pressure sensor I could optionally use pressure sensor instaed of throttle on the fuel map. Also I could use the pressure sensor instead of the airflow sensor on the timming map, I'm not sure which is better here if it even matters.
Hehe.
