mccurdy
- 405
- 0
- Jul 25, 2003
Ok...I JUST put a new 2.5 inch o2 sensor housing with a dump tube in tonight. I disconnected the o2 sensor from its plug, unbolted the coolant hard line, drained the coolant. Disconnected the o2 stock housing. Rebolted the new o2 dump housing. Reconnected the o2 sensor in the new o2 housing. Reconnected the coolant line, refed coolant into the car. I took off the bottom heat shield, but left the top mani heat shield on.
I ran the car for like 10 minutes, and it ran incredable. It sounded mean as hell, and flowed great! Then i tried launching it and max psi (about 21 lbs of boost) on my profec-b with the balance set at maximum. I hit about the middle of 2nd at full boost and BAM. car buckles HARDCORE. i slow way down, and try to accelerate again. It goes from -24 vacuum to 0 psi perfectly normal, almost instantly like it should. But from 0 to 5 i noticed it was slower. then anything after 5 psi, the car starts Hesitating big time, and actually starts slowing down the higher the PSI i go! It also makes a really wierd noise.
I have no white/black smoke i can tell from the tailpipe. Im still using the origional o2 sensor, i have no check engine lights, no visual signs of any leaks anywhere.
I CANNOT FIGURE IT OUT!!! What would make the car hesitate and slow down under boost, yet it goes from vacuum to 0 psi perfectly normal! I can drive it fine under boost and get it up to 90 MPH and drive it on the freeway just fine, yet if i try to mash on it, it just bucks/hesitates and slows WAY down!
Please help guys, i have till monday to figure out this problem!
i cant believe how much power difference it is, especially off the line opposed to the stock o2 housing. Just imagine if i beat a WRX by the end of 2nd gear without the o2 dump, wonder what i could do now....
