dizzygsx
- 0
- Oct 4, 2002
My car crankwalked about 4 months ago and I replaced the block with the remanufactured block from Mitsu. I didn't want to do a 6 bolt because I already had everything I needed for the 7 bolt and thought I would be able to get atleast a year or two out of the new 7 bolt and I was told that it had a much less chance of crankwalking. Basically I was getting a new bottom end and the head worked. It was actually the cheaper way to go and had the longest warranty. Well, 6k miles later and CW again. I know there is nothing to prevent it from happening but what should I do now? I don't really want a 6 bolt with 100k+ miles on it. Is there a different thrust bearing that can be used that is better? Someone had mentioned TRW bearings. Has anyone heard anything about this?
