People with 97-99 Bumpers who cut the black strip on the mouth.. Process?
RedTurboEclipse
5,613
42
Jul 29, 2002
Bay Area, California
hey guys.. im in the process of doing my 97-99 conversion.. and i do have an FMIC.. ive made up my mind on cutting the black strip above the mouth of the front bumper.. now i was wondering for those of you guys who have done this.. if it was an easy process.. and how exactly you guys did yours..
i think this would make a great write up for the FAQ/Write up section as well ;)
Its really easy man...use a dremel..and go slow..on a high speed...and wear a mask of some sort..cuz that shizznit smeels really bad...but its very very easy..and use the thick cut off heavyduty wheels..
Just be real conservative with the cutoff wheel- once those little bastards start to wander, it's impossible to get them back on-line. Leave yourself at _least_ 1/16" trim and cleanup margin.
the bumper support has to go!!!
I dont know what you've been smoking, but the support goes as low as the stripe - ie if you chop of the stripe, its not gonna look too different since the support is there. looks like this
It's not a big deal, you just have to cut a notch in the plastic bumper as well. Took me 15 minutes. Just fit the bumper cover over the bumper once you've cut that strip out and then trace where the bumper needs to be cut and go to town.
Doesn't that really effect the structural integrity of the bumper system. I'm just worried that insurance might not cover my car incase my car gets into a front end collision due to so much hacking of the front bumper (I've already hacked the side of the re-bar because of the FMIC).
The black plastic thing is only a 5mph bumper so in case you slowly roll into something you dont end up with a cracked bumpercover it also give the bumper cover some rigidity to it. If you got into a front end collision and hit a pole going 25, the plastic piece wouldn't do jack.
(I left mine on, cut up because it helps support the bumper cover and gives extra protection to my $1000 investment.)
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
  • Wanted [WTB] Hyundai 4g63 inner valve cover bolts
    Looking to source inner valve cover bolts for a Hyundai 4g63 valve cover
    • TheDude236
  • For sale 2g VRSF 2g FMIC.
    Bar and plate. 28x10x3.75. 2.5 inlet and outlet. 36.5 on center inlet and outlet Pretty...
  • For sale 2g Eclipse/Talon Passenger Side Fenders
    95-99 Eclipse/Talon Passenger Side Fenders
    • Sdcryan1
