asian312
- 678
- 4
- Sep 23, 2002
Houston,
Texas
With every holiday season follows a new year. And with that new year brings change. Many times that change is fueled by new drive, ambition, or in my case a new turbo!
I'm honored to be the first to sport Turbochargers.com newest "Eliminator" turbo variant.
Yeah the tag is there, but there is a reason. It's called the "Eliminator" strictly for the reason that it does not require the "j-pipe" from the 2g install kit. What will u need, the oil feed and return lines. Well enough with the boring stuff, lets get to the nitty-gritty.
What exactly is it.
Breakdown:
- Garret T3 comp housing (machined)
- 7cm sqr turbine housing
- 46 trim comp wheel
- TDO6H turbine
- Monster Thrust Bearing
Just recieved it today, and hopefully will be up and operational early Jan. to kick off the new year. Mucho thanx to Wade, Tommy, and the rest of the guys at Turbochargers for letting me take part in bringing in the new year!
Pics below
Yeah the tag is there, but there is a reason. It's called the "Eliminator" strictly for the reason that it does not require the "j-pipe" from the 2g install kit. What will u need, the oil feed and return lines. Well enough with the boring stuff, lets get to the nitty-gritty.What exactly is it.
Breakdown:- Garret T3 comp housing (machined)
- TDO6H turbine
Pics below
, Actually the main reason y is b/c that was what was on the table to play with, j/k. This is really a senior variant of Wade's turbo (ask him he's jealous). The only changes were the T3 comp and TDO6h instead of the 16g and TDO6 if my memory serves me correctly. I'm getting to preform some of the inital tests and what nots. Oh yeah, did I mention dyno time on
Very nice turbo. Please keep us updated as the install progresses. I'd be very interested to see what kind of numbers this thing puts up. Too bad I need a J-pipe for my 14b.
Anyways, I'll get off my lazy a$$ and punch out a review. Still need the new injectors to really make her sing, but at 15lbs of boost with the stock 450, she'll out run just about anything. Can't name anycars b/c none of the TAs and Camaros in my area wont race me :laugh:
