How to install shift light.
Davidle
1,212
Jun 10, 2002
Vancouver, Washington
I just bought a shift lite and was wondering where the wire goes to. The black is ground, red is to the battery, and where does the other one goes?? thanks for the help.
why the CAS? its a shift light.. should be power/ground/rpm signal
now that I said that I guess the CAS could give an RPM signal but Id say your best bet is the tach wire in the ECU.
http://www.vfaq.com/mods/ecu-harness-2G.html
I just cross referenced the S-AFC install guide which says to use pinout #58 for the RPM signal for the AFC, Id assume you would use the same one for a tach or shiftlight.
Its like the proautometer shift light. It lights up blue when it hits the certain RPM's. Thanks for the info Larryd. Its pretty nice to have, all you do is insert the pills, and bam, it lights up when it hits it.
For a 1G, it's the CAS. Using the cross reference for S-AFC install should work just fine.
  • Wanted 1g Looking for pn MB522081
    Looking for a factory 1g double din radio bezel pn MB522081
    • Kgilis
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
  • Wanted [WTB] Hyundai 4g63 inner valve cover bolts
    Looking to source inner valve cover bolts for a Hyundai 4g63 valve cover
    • TheDude236
  • For sale 2g VRSF 2g FMIC.
    Bar and plate. 28x10x3.75. 2.5 inlet and outlet. 36.5 on center inlet and outlet Pretty...
